61 rear spring height measurement - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    I have my rear springs apart and cleaned. Is there any measurement I can make while they are apart to determine if they will need to be rearched? Better now than after they are installed in the car.
  • Edward L.
    • 278
    Re: 61 rear spring height measurement
    Jerry:
    I too needed this information and a friend of mine just provided it not more than an hour ago. The info came from a Restorer magazine issued in 1979.
    These measurements apply only to the long spring:
    The measurement from the center of the eye to the center of the opposite eye should be 51". From the center of this measurement to the spring should be 3 5/8".
    Ed
    • Steven B.
      • June 30, 1982
      • 3976
      Originally posted by Edward Lepelis (22093)
      Jerry:
      Ed
      Do these measurements hold for all '53-'62 standard suspension cars?
      • Edward L.
        • 278
        The measurements I gave are for standard 53-62 four leaf springs.
        • Steven B.
          • June 30, 1982
          • 3976
          Thanks Ed!
          • Jerry G.
            • April 1, 1985
            • 1022
            I did the measurement and I got something different. Going from center of mounting bolt to center of mounting bolt I get 49 1/2 inch. I do get 51 inches if I measure outside to outside. For the arch I get 5 3/4 inch measured from the floor to the bottom of the center of the arch. If I subtract the distance from the center of the mounting eyes on the end I get 5.0 inches. The spring are four leaf with standard part number but they are on a big brake car. I don't think that would have anything to do with these measurements. Anybody have any ideas whats up?
            • Edward L.
              • 278
              These measurements can be found in the Restorer, 1979 Vol. 6 #1
              • Bill M.
                • April 1, 1977
                • 1386
                The eye-to-eye measurement isn't important. It will get longer as the spring gets flatter. Looks like your springs are about 1-3/8 higher than the spec. I would consider doing a trial measurement of the springs before you install the anti-splay clips. Just bolt them together and install them. If the car sits too high, have them shortened. When you're happy with the stance of the car, install the clips.
                • Jerry G.
                  • April 1, 1985
                  • 1022
                  These are all original springs. So I'm assuming physical shortening won't be need. Sounds like i should follow your advice and bolt them together and see where I'm at.
