67 "DC" master cylinder casting dates - NCRS Discussion Boards
  • Page C.
    • February 1, 1979
    • 802
    Re: 67 "DC" master cylinder casting dates
    Hi Bill,
    Looked at the original master cylinder from #2232. It is a #509 casting with the bleeder screws above the line connections. It has the DC stamped in the machined area on the front end. There is some type of casting # on the side where the lines connect in line with the front bail. It appears to be an upside down D1. This might be a mold number. Nothing on the bottom.
    Page Campbell
      Originally posted by Page Campbell (2299)
      Hi Bill,
      Page Campbell
      Page----
      The "D" represents the old Danville, IL GM foundry where these master cylinders were cast. The "1" is likely a pattern number. Danville was a nodular/ductile/malleable cast iron foundry.
      • Bill C.
        • May 31, 1989
        • 424
        #18
        Page,
        Thank you for looking, and responding, just to be certain there is no date code cast into the housing just below the D1 (which is a mold#)? That is exactly what I am trying to determine, if original 67 masters up to Jan 1st of 67 had no cast date code, I am thinking they started the date coding then? Possibly earlier?
        Bill
        • Page C.
          • February 1, 1979
          • 802
          #19
          Hi Bill & Joe
          There is no casting date on the master cylinder. Only the #509 casting number and the mold number.
          Thanks Joe for the info on the "D"
