72 LT-1 Engine, CKY
Re: 72 LT-1 Engine, CKY
I may have the answer to all of this. From an on-line source:
CKY 1972 350 four spd trans. L LT1 255 4 Vette/1200
CKY 1973 350 m/t, 4 spd NB2 L65 145 2 Camaro
One will have to look at dates closely. If the casting date(s) could fit a 1973 model year vehicle then it would be the Camaro block (I would guess a 2-bolt case) 145 hp with a 2-barrel carburetor, AND there is the NB2. If the cylinder case is early enough for a 1972 model year then we have an LT1 engine (4-bolt mains for sure) and of course a 4-barrel Holley carburetor. And what of those cylinder cases late in 1972 MY but still early enough for an early 1973? Well the 2-bolt v 4-bolt is the only distinguishing feature unless some of the rotating assembly is with it. Cast v forged crankshaft, and the pink paint marks on the rods.
Louie you probably disassembled a Camaro engine. Thanks for mentioning it though, because it gave me the clue to look for a reuse of the CKY code. They usually didn't reuse the codes so close together -- they are usually a couple of years apart.Terry- Top
