I have a new set of the aluminum starps that hold wire/hoses. Can anyone with a 62 point me in the right direction of wher in the engine compartment they go?
1962 Engine compartment straps
Re: 1962 Engine compartment straps
Hi John Section B Sheet 11 shows 5 of them on WW hoses key 5. Then on Section B Sheet 15 it shows one on heater hoses 5.50 in. from the angled nipple on pump. Sounds a little critical but if you put it like it shows you don't have to worry about the hoses getting into the belt. Good Luck- Top
