58 Carter Carb & Intake - NCRS Discussion Boards
  • Dennis G.
    • March 1, 1993
    • 100
    I bought a 1958 passenger car carb, intake and some other parts to use on a 1958 Corvette. The carb has a 6-1386 throttle body, a 0-208 main body and a 6-1299 air horn. Was the passenger carb air horn different then the 6-1354 the Judging Manual specifies? It has a 2669S brass tag with a M7 date. I guess it could have had a rebuilt carb put on at one time. The intake has a 3748828 casting number with a A158 date code so I am assuming the passenger intake was different even though the horespower was the same?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 58 Carter Carb & Intake
    1958 passenger car carb is not the same as Corvette or in design but will work with your car intake OK.
