I searched the archives regarding the 1969 half shaft finish on the 1969 small blocks. The consensus is that the half shaft was shot peened on the big block, and left natural steel on the small block with some heat bluing near the welds.
So question 1, is that if this bright finish seen below would be technically correct for the 1969 small block?
Quesion 2 is whether there was any stripes painted onto the half shaft similar to the color coding bands often seen on the drive shafts of the old GM A bodies? I've seen that done in photos but am doubting that's correct as they only had the (2) types.
I was simply going to sandblast and paint the half shafts a stainless steel paint and call it good.
But these are so pretty it's awfully hard to resist, but at $159 each, would like to make sure they're absolutely the correct finish.
