I am getting my rolling chassis ready to set the body back on. I wanted to set the preliminary caster, camber and toe before setting the body on. I was able to set the left front camber at 0 degrees. The right front will not set. I have the nuts on the upper a-arms backed all the way to the end of the threads, and I am still at 1.5 degrees positive camber. In between the frame mounts where the control arm bolts go through measures 26.5 inches. I believe this is in tolerance with the specs. I changed to a different spindle, but have the same problem. The frame checks out square measuring diagonally. The dimensions are correct from center line to the 2 body mounts on the driver side that the service manual states. Any ideas? Thanks, Mark
Can't Get Front Camber Set Right
Re: Can't Get Front Camber Set Right
The service manual has a diagram of the frame and measurements. I would compare it with the diagram. Are you sure there is no frame damage? I had my frame checked by a auto body shop that used laser measurements. I had this done because there was allot of welding on the frame. Once you put the weight back on the care you will probably have to have it aligned again.- Top
Unless you have the chassis set at the proper Z and D dimensions, you're wasting your time. If it's a rolling chassis the lack of weight from the body means the ride height is way too high. As the ride height increases, camber increases in the positive direction.
Duke- Top
Yeah...
The C2 has rather high suspension roll centers. This provides high roll stiffness from the springs, but yields considerable camber/track change through the range of jounce and rebound. This was a clever design feature and was okay with skinny bias ply tires of the day.
Modern cars -especially those with wide, low profiles tires have much lower roll centers, which yield less camber/track change, but they need stiffer springs and big anti-roll bars for good roll control.
Compare a C2 on a lift with the suspension drooping to a modern car on a lift and you get the idea.
Duke- Top
The rear roll center was reduced a couple of inches in '68, but the C3 front roll center was unchanged from C3.
This means the C3 rear suspension shows less positive camber at full rebound than a C2, but the front is the same.
Duke- Top
