I just experienced a potentially major problem, but fortunately it didn't do any damage. The black wire going to my battery gauge under the dash caught on fire. My cousin and I were able to put it out fairly quickly. I think all I have is some smoke and soot to clean up.
My question is why did this happen. I'm sure I did something wrong but I want to understand what I did.
Here are the facts.
1) Per a couple of the posts I found on here, I reversed the leads going to this gauge since I was reading backwards before. This is opposite from the AIM.
2) We were trying to get the motor started. We had run the starter quite a bit and were changing the timing to try to get it to start.
3) We were using a battery charger on the "start" setting along with the battery.
Are any of the above items part of the problem. I can't say for sure that a wire wasn't pinched or something, but it is hard to tell at this point.
Any thoughts or questions would be appreciated. I need to be comfortable that I won't do this again.
Ashley
Here are the facts.
Ashley
