1968 Windshield Washer Nozzle Finish - NCRS Discussion Boards
  • Russ T.
    • May 31, 1989
    • 113
    I am having my early production 1968 convertible painted and
    am not sure what finish that the washer nozzles should be.
    My painter says that they should not be painted the body color
    (International Blue). Nozzles were purchased at Carlisle last
    summer (OUCH !!!). Any help would be appreciated.
    Russ Trotter (#15044)
  • Grant W.
    • December 1, 1987
    • 407
    Re: 1968 Windshield Washer Nozzle Finish
    I think they were Zinc phosphated black for the early cars and then semi flat black paint for the later 68 cars. When install it will be partially painted on the top. Make sure you have the early correct wiper grill as it has the cut outs for the washer nozzel.
    Also the 68 grill mounting brackets including the lower ones rivoted to the lower valance are all zinc phosphated black.
    Also the 68 early door sills are different from late 68 to 75.
    Also early 68 front bumper is different.
    Anyone else can chime in???
    Thanks, Grant
    • Henry J.
      • November 1, 1999
      • 457
      The windshield washer nozzles on my early 68 (115xx) are as Grant describes: zinc phosphate black
      • Terry B.
        • August 31, 1999
        • 607
        "Also the 68 early door sills are different from late 68 to 75.
        Also early 68 front bumper is different."
        Grant,
        Please explain what you mean about the door sills and front bumper. Pictures would be great.
        Terry Buchanan
        Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
        Corvettes Owned:
        1977 Coupe
        1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
        2003 Electron Blue Coupe
        2019 Torch Red Grand Sport Coupe
        • Grant W.
          • December 1, 1987
          • 407
          HI Terry
          Pic of the front edge with early door sill at the top. Top view pic with the late door sill on the bottom. On top is the early 68 door sill. Notice the width on the side is much wider. Very hard door sill to find.
          Bumper 68 as pictured, noticed the straight edge on the bottom7. Late 68 to 69 and possibly 70 on the bottom It has the 3 round notches.
          Please note the square edged of the mounting bracket with slight shaved edge about 3/4 inch. That is correct for 68 to 69 and possibly 70. So many people replace with an incorrect 71/72/73 front bumper and find out it is different and they cut the extra bend but still not the same as the width of the 68/69 front bumper mount is wider.
          Hope this helps.
          Grant
          • Erik S.
            • January 1, 2005
            • 407
            Grant - what is 'early' in this context (eg approx when was the change over as far as you know?)?
            Erik
            • Bryan M.
              • April 1, 1999
              • 386
              HI Terry
              Hope this helps.
              Grant
              Great pics Grant! Do you have a pic of an original 68 a/c'd SB idle solenoid set-up?
              • Jack C.
                • September 30, 1992
                • 1090
                I have #9643 which is considered "Early" I believe around 10,000 is where it starts no longer early production. This info was garnered at judging meet last year.
                Jack Corso
                1972 Elkhart Green LT-1 Coupe 43,200 miles
                Top Flight 1994, 2018 & 2021
                • Terry B.
                  • August 31, 1999
                  • 607
                  Grant,
                  I have never heard the information about the door sill and the front bumper on a '68 before this and I have been in the process of restoring mine for the past 9 years. Thanks for the pictures. Do you have the aporoximate vin #'s where the changes occured?
                  Perhaps you all ready know the '68/'69 judging manual is in the process of being redone. This information along with the pictures would be very helpful to the restorer and judges. You can submit the info on the sign in page of this discussion board. Just scroll down to the bottom and find the correct category.
                  Do you have anyother '68 abnormality that you would like to share.
                  Thanks, Terry
                  Terry Buchanan
                  Corvettes Owned:
                  1977 Coupe
                  • Henry J.
                    • November 1, 1999
                    • 457
                    Grant:
                    Would you please provide some dimensions of the cross-section of the 68 door sill? Overall cross-sectional width would be very useful. Thank you.
                    • Grant W.
                      • December 1, 1987
                      • 407
                      Erik
                      Hi Eric
                      Early is what I consider 68's be Assembled in Sept 67, Oct 67 Novn67 Dec 67, That would be vin 00905 to vin 10000 as Jack's car is. His is an early one. His car is probably assembled very late Dec 67
                      Thanks, Grant
                      • Grant W.
                        • December 1, 1987
                        • 407
                        Hi Bryan
                        I may have the solenoid set up somewhere. I have to find it. Also for your information. 68 s/b A/C fan is a one year part only. I hope you have the correct one for your car. Another revision for the judging book!!.
                        Thanks, grant
                        • Grant W.
                          • December 1, 1987
                          • 407
                          Originally posted by Terry Buchanan (32872)
                          Grant,
                          Thanks, Terry
                          Hi Terry
                          Its been 10 years restoring my 68. I'm finding out stuff that I never knew either. Just found out 68 S/B A/C cars used a one off fan. Its in the parts book and I had thought it was a B/B fan blade for the L88 but I took it off an original 68 435 hp car. So in some cases as Joe and I discussed it could have been used. But the B/B fan blades has a deeper pitch. So we figured it was not for an 435hp car or L88 but for that rare 68 A/C cars.
                          The width of the early 68 door sill is 4 x 9/16th wide. I can only guess this came on the Sept 67 to very very early Dec 67 assembled 68 production corvette. I don't think it came on the Jan assembled 68 cars.
                          I will try and figure out how to submit to the revision of the 68/69 judging book.
                          Hope the pics help.
                          Thanks, Grant
                          • Bryan M.
                            • April 1, 1999
                            • 386
                            Hi Bryan
                            Thanks, grant
                            I've been looking for a photograph of one actually installed on an original 68 sb 4-speed with a/c. Haven't found one yet!
                            • John C.
                              • January 1, 2005
                              • 616
                              Grant
                              Out of curiosity I'm wondering how do the plastic headlight shields get attached without the three U notches in the bumper that allow access to the screws?
                              John
