Straightening Holley carb parts - Clem Zahrobsky?? - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Straightening Holley carb parts - Clem Zahrobsky??
    Originally posted by David Duell (43184)
    I am by no means an expert, but, over on another forum, when this conversation came up, the replies were....
    "With a proper fixture these metering bodies can be pressed straight as i have been doing that for years. NEVER machine them flat as you will remove all the protrusions that "bite" into the gasket to help it seal."
    Any truth to this? Or is machining flat an acceptable procedure?
    David
    sounds like one of my posts and yes that is true. PS i straighten mine cold but i guess you could use some heat.
    • Clem Z.
      • January 1, 2006
      • 9427
      Forgot to add one thang.....THROW AWAY THE BIG SCREW DRIVERS!!!
      if you think that is a problem how about when holley changed to hex head bolts. i get them now with the threads pulled out of the main body.
      • Clem Z.
        • January 1, 2006
        • 9427
        Originally posted by Michael Ward (29001)
        Glad to hear that his sugar daddy came through
        THANK YOU FOR ALL THE SUPPORT and i will try and live up to my campaign promises.
        • Bryan M.
          • April 1, 1999
          • 386
          Clem,
          Glad the bail out money came through
