Question,Where does the green 1816 bulb behind dash go?? - NCRS Discussion Boards
  • Fred Y.
    • April 30, 2000
    • 319
    Hello everyone,
    I have my bulb marked/labeled reinstall behind clock,but I don't see it in my AIM.I have a long socket w/an 1816 bulb in it behind the dash that has a plastic green cover over the bulb section & when I disassembled 13 months ago I marked it "mounts behind clock"----but I'm not sure if that's right!!Appreciate some help!!
    Thankyou Fred
  • Keith B.
    • March 7, 2008
    • 928
    Re: Question,Where does the green 1816 bulb behind dash go??
    would it go for your heater switch knobs or radio knobs.
    • Wayne M.
      • March 1, 1980
      • 6414
      Originally posted by Frederick Yankocy (34048)
      ..... I have a long socket w/an 1816 bulb in it behind the dash that has a plastic green cover over the bulb section & when I disassembled 13 months ago I marked it "mounts behind clock ....
      Hope this poor picture helps. This is taken from the instrument panel side (which is out). The square-ish box is the top of the radio. The clip on the long cylinder with the green shade on the bulb slides into a slot at the bottom of the metal semi-circular clock bracket. The greenish light shines on the plastic bezels of the controls on either side of the clock.
      This is a '65 with 43 years of dust, but am sure it's the same on a '67.
      A/C cars have another auxilliary wire harness with a bulb at the top of each side of the clock bracket, to illuminate the controls at the top of the clock.
      • Fred Y.
        • April 30, 2000
        • 319
        THAT'S IT !! Wayne thanks very much !! Fred
