72 454 non-ported mapping curve specs and parts - NCRS Discussion Boards
    • 15610
    Re: 72 454 non-ported mapping curve specs and parts
    You can use a 15" VAC. I've listed the part numbers a zillion times when this discussion comes up, but my fingers are getting tired.
    • Timothy B.
      • April 30, 1983
      • 5177
      Robert,
      Sounds like your on the right track with the distributor, I think your car will run much better when you finish. Just remember not to exceed total advance (inital plus centrifugal), vacuum advance is in addition to this..
      • Robert B.
        • March 1, 1999
        • 43
        #18
        Thanks for the info
        • Robert B.
          • March 1, 1999
          • 43
          #19
          Thanks for all the help. Car is running fine except maybe idle could be smoother (I have nothing to base a smooth idle for a big block). The new vac advance works well timing is correct, etc... I was able to review other posts and found a lot of Duke's archives) very informative and I have learned a lot.
          Rob
