I was thinking it would be interesting to list parts that only one year Corvette used. Parts that no other year did. Here are a few I can think of off the top of my head. How about you posting pic's of the same about your year Corvette.? Like 58 or 65 and so on.
1 Rotor using a piece of carbon to reduce Radio static 55 only
2 Heat Riser "Tomb stone " #3721512 in bossed 55 only
3 Vacuum advance #1116085 in bossed 55 only
4 #086 coil cad un-painted 55 only
5 Heater shut off Mickey ears 55 only
6 Gen. Condenser soldered on bracket 55 only
7 Starter solenoid front cover having one post "S" 55 only
8 Coil condenser Chromed 55 only
9 All glass seal beam headlight 12V logo 55 only
10 Air cleaner no recessed for choke bottom painted gray 55 only
11 Coil bracket 55 only
12 Mallory Condenser 55 only
13 Shielding Dist and coil 55 only
14 Plug wires support 55 only
15 Oil pan 55 only
16 Carb base plate first design 55 only
17 #5 Rad. Shroud piece bottom area 55 only
