wiper door act safty sw - NCRS Discussion Boards
  • Richard C.
    • July 31, 2001
    • 144
    i think i have a bad sw does this switch have vac at all times at the VENT hose? this is after market there is NO screw adj on the end. even when pushed in to close wiper door still has vac at VENT hose.
    • 6940
    Re: wiper door act safty sw
    Rich, Does The Wiper Door Creap Up After You Shut The Car Off ,i Have A 72 Coupe- The Solonoid Behind The Tach Was Bad.
    • Richard C.
      • July 31, 2001
      • 144
      edward THANKS for the reply no the wiper does not creep up. i dont think the vent hose should have vac when door is down
        • 6940
        Rich, is that the only problem, everything else operates okay.that wiper door can have so many different types of problems.
          • 3415
          Hi Richard,
          I'm not sure if you're asking about the 'wiper door 3-port interlock switch' under the right wiper arm or the 'wiper door solenoid valve switch' behind the tach.
          • Richard C.
            • July 31, 2001
            • 144
            yes alan the switch is under the wiper door on rh side,edward yes the door does work .
              • 6940
              Alan,
              I beleave he is talking about the switch at wiper arm r/side ,it has vaccum at vent hose while engine is running.
              • Richard C.
                • July 31, 2001
                • 144
                edward how much vac should there be at the vent hose?and should the vac go away when the wiper arm goes down and hits the valve?
                  • 6940
                  Richard,
                  I beleave that that this is the normal operation- when the function of the door is not needed the vent is used to let the door stay put in closed position.
                    • 3415
                    Re: wiper door act safety switch
                    Hi Richard,
                    Here goes...
                    put vac. on unmarked port, keep plunger in, unmarked port should maintain vac. while red and white ports are open.
                    put vac. on white port, keep plunger out, white maintains vac., unmarked and red ports are open.
                    Red port is always open regardless of plunger position.
                    • Richard C.
                      • July 31, 2001
                      • 144
                      thanks alan unmarked will not hold vac but white does, gess i have a 3rd bad switch i have bought the sam switch from diffrent vendors, dr rebuild switc at least his holds vac on the white port
                        • 3415
                        Hi Richard, Again,
                        A few years ago when the reproductions first appeared, I was interested in a getting one. The vendor, at Carlisle, 'tested' the 6 he had with his mouth and couldn't get any of them to 'work'. He gave me one and said maybe I could fix it. These were the ones with the white plunger.
                        • Richard C.
                          • July 31, 2001
                          • 144
                          Alan, THANK YOU for helping me with this dog gone switch!!!!!!!!!! i am sorry to take up so much of everybodys time. i think if enough people complaine they will fix this problem???????? alan maby i could call you or you call me at my shop, 615-255-3939. i do better on the phone
                            • 3415
                            Hi Richard,
                            I'll try to call you tomorrow.
