Fuel and brake lines - restore or replace? - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 660
    Any opinions out there as to whether to try to spruce up the appearance of my original C-1 brake and fuel lines or bite the bullet and replace them? The lines are all functional as far as I can tell but don't have that "new"appearance. Not sure what can be done if I keep the lines and try to spruce them up - maybe an external acid wash?
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Jim L.
    • September 30, 1979
    • 1805
    Re: Fuel and brake lines - restore or replace?
    To me, this is a safety issue that transcends any consideration of originality or cosmetics. You just don't know what they are like on the inside and can't know until and unless one of them fails. I'd replace those lines in a heartbeat and not think twice about it.
    Jim
      • 11608
      How bad do they look? Are they rusty? Or just "don't look new?" Is your car a Bowtie candidate, or just a driver? All of these factor into your decision.
      Right now I'm working on a 72 for a friend. It's not quite as nice as my 72 Bowtie car, but it is very original. Unfortunately between July when I last worked on the car and Dec 31st when I hauled it out of his grandma's barn, the fuel line rusted a major leak. Despite the car's originality his goal is to have the car fixed up/repaired enough to drive it and have it reliable. So, the original lines are going to be replaced and he's not going to worry about losing that item if he ever attempts a Star/Bowtie Award.
      Just an example for you.
      Patrick
      • David W.
        • December 27, 2007
        • 81
        Patrick it sounds as if you have experience replacing fuel lines with the body in place. I am getting ready to try this on a 1980 model. Any advice or trick I am missing? Regards, David
          • 11608
          Actually, I'll be doing it soon. I've done brake lines on other cars, and the fuel lines on this one will likely be in 2-3 weeks. In fact was doing brakes on a 1960 yesterday after I reinstalled a caliper on my 72.
          I don't know any more than what's already been mentioned in your previous thread when it comes to fuel lines.
          I'll be using our lift, that's for sure.
          Patrick
          • Keith R.
            • August 31, 2001
            • 660
            Thanks. Just wondering if the aftermarket replacements fit as well as the originals and whether there's any benefit to leaving the originals on there for Flight Judging vs. new replacements. I'm guessing that there is no real benefit and perhaps a real negative from a safety standpoint. I hear that I should salvage the brass connector blocks however before pitching the old line..
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
            • Jim L.
              • 1805
              The original brass blocks will have small internal deformations that were created when the original brake lines were initially mated to them. It is the ability of the brass to deform that helps an inverted flare fitting seal well.
              Consequently, if you reuse the original brass, you may have some difficulty getting it to re-deform to fit the new lines. It's a crapshoot. About half the time when I try to reuse old brass I get uncorrectable leaks.
              From a technical standpoint, it would be better to replace the brass, in my opinion.
              Jim
