Changing Bushings - NCRS Discussion Boards
Changing Bushings
  • Paul L.
    • November 1, 2002
    • 1414
    Re: Changing Bushings
    Originally posted by Kenneth Tozzi (48795)
    Tom,
    I hope you were not holding your breath waiting for an answer, but here it is.
    The pictures below are original rubber diff mount bushings(cushions)
    The diameter of the large bushing is 2 5/16" and 1" thick. It has a metal washer imbedded on the bottom.
    The top cushion is 1 3/4" OD. The rubber only, without the metal sleeve and washer is 1/2" thick and the hole is 5/8".
    See attached pictures.
    Ken
    FWIW on the differential snubber, here is the difference. Poly is on top and rubber on the bottom. I am not technically competent to say what performance characteristics are associated with each application. I intend to put the rubber unit on this spring. If anyone needs additional pics they are sitting in my spring things-to-do box beside my computer.
