I'm down to my last non-operating item to fix. My washer pump has a crack in the cylinder extending from one of the valve assembly cap screw holes to about half way down the cylinder. I have three options.
1. Try to repair the crack.
2. Replace the washer assembly with a BLACK replacement because I can't find a correct WHITE replacement.
3. Replace the cylinder with a WHITE replacement from another GM vehicle.
Why the correct white plastic is not being used for the replacement part is beyond me but I guess there must be a reason. I have found a white pump at a Camaro parts supplier to fit 67-69. Since the 69 Camaro also had headlamp washers I thought that the cylinder for this pump may be adaptable to my washer assembly.
Does anyone have any info or insight on repair or replacement of these washer pump cylinders? I have heard that the pump cylinders for units with headlamp washers were higher volume than other units. Is this true?
Here's a photo of the Camaro part available for $70.
