Can someone tell me if the backing plates for 63-64 drum brakes are available? I am not having much luck locating replacements.
63 drum brake backing plate
Re: 63 drum brake backing plate
I do not have the part numbers available to confirm this, but I'm under the impression the brakes shoes are the same as the full size early 60 Impala. Thus the backing plates and brake cylinders and brake parts may be interchangeable. You may be able to cross referenced usable part numbers.- Top
Believe it's 3858826/825 for right/left and called a plate.
The ebay items may not be correct, at least for a Mar64 car. Look for 4 holes tomount on control arm, the center area comes up to far, the hole for cylinder mount is wrong configuration and no added on support for upper center nut.- Top
- Top
John,
Didn't know there was a Lou Jr. Excellent, I look forward to meeting him someday. Is he planning on going to NCRS Florida like his dad always did?
JR- Top
OK at least per the
65 parts book, the '63-64 Brake backing plates 3832519 and 520 are the same for 63 and 64 pass and corvette applications, except SHP brakes. Rears are Corvette only 3847719-720 again except SHP brakes.Bill Clupper #618- Top
