I need information on specific details of the harmonic balancer and pulley for an early March build Corvette, vin 2665, 283, 2X4 carb, high lift Duntov cam engine.
Diameter of balancer, thickness of balancer, diameter of pulley, deep groove,
width of groove, pulley riveted or bolted to the balancer? Same as the FI engines. In researching the archives information indicates the 250 hp fi engine had a riveted pulley and the 283 high lift cam solid lifter engine had a bolted on pulley. GM part number, any casting numbers or stamping numbers? Do we have an expert on this??? Thank you. JG
Do you have the '56-'57 Judging Guide?
