67 327 heat riser operation - NCRS Discussion Boards
  • John S.
    • May 4, 2008
    • 424
    Should the heat riser valve be full open at idle with the car fully warmed up? Mine is closed until I start to give some gas then it opens.
    John Seeley
    67 Black/Teal
    300 hp 3 speed coupe
    65 Maroon/Black
    35k mile Fuelie coupe
    Re: 67 327 heat riser operation
    John-----
    The way you described it is the way they work. I've never seen one that fully opened at idle with the engine at operating temperature.
    • John S.
      • May 4, 2008
      • 424
      Thanks Joe. I was just looking at the archives and found tons of stuff on this issue. Guess I will look there first next time. I think I am going to take Duke Williams advice and wire mine open and see if it takes care of the problems I have been having.
      John Seeley
      67 Black/Teal
      65 Maroon/Black
      • Stuart F.
        • August 31, 1996
        • 4676
        John;
        It all depends on what problems you are having, but many cases, it is worth a try. However, I've been playing around with things on mine to overcome a severe fuel percolation problem. I have that solved, but in the process picked up several other minor issues incl. low speed lean surge and off idle stumble. I have limited both of those by removing my wire from the heat riser and going back to an automatic choke (from an electric). For what it is worth, I found that there is between 1.0" and 1.5" hg (vacuum) pull through the auto choke. When I use the electric, the heated air pulled through the choke is cut off and, of course, that has an effect on your mixture.
        Stu Fox
          John;
          Stu Fox
          Stu-----
          1967 uses a completely different choke system than that used for 63-64. Wiring open the heat riser can slightly affect choke operation for a 1967, but, in most cases, the difference will be minor and not even noticed unless one operates the car in a very cold environment. No other choke-associated problems should occur for a 1967 if the heat riser is wired open.
          • Stuart F.
            • August 31, 1996
            • 4676
            Joe;
            Thanks for the clarification. I guess the main point I wanted to make is that wiring open the heat riser is not necessarily a panacea (cure all). To make the example I used a little clearer, I should have said "the mixture" or "my mixture", recognizing there are so many different systems out there.
            Stu Fox
