T3 Headlight Numbers - NCRS Discussion Boards
  • Mark F.
    • June 30, 1995
    • 60
    Anyone out there know how to decipher the date codes on T3 headlights?
    Mark
  • Harry S.
    • July 31, 2002
    • 5258
    Re: T3 Headlight Numbers
    Mark, check the archives. A chart was posted with the codes.
    https://www.forums.ncrs.org/showthre...ights&uid=3344
    • Mark F.
      • June 30, 1995
      • 60
      Thanks Harry. I did try and search the info before I posted but did not come up with your fine schematic.
      I was surprised to see that there are no date coding references to the small numbers cast into the glass on the front of each bulb. Are these figures just "noise"?
      Mark
        Mark
        Mark -
        I'd expect that those are mold numbers from the lens-forming process.
        • Michael H.
          • January 29, 2008
          • 7477
          Mark
          I hope this is clear/big enough to read. If I make it larger, it won't upload.
          • Mark F.
            • June 30, 1995
            • 60
            Thanks all. That was very helpful!
            • Mark F.
              • June 30, 1995
              • 60
              Hello all
              A week or two ago, I asked for help in decoding T3 headlights. Harry Sadlock pointed me towards his snappy schematic. From this I have determined that 3 of 4 T3's in my 65 fuel car are original to the car. The dates are as follows: the two 4002 lamps are 1-20-65 and 1-25-65 and the 4001 lamp is 1-25-65. The cars build date is 2-8-65. I don't know how many of you have seen the ink stamp dates, so as a way to add a little value to the board, I took pictures of the stamps on my lamps. Thanks to all for the help!
              Cheers!
              • Joseph T.
                • April 30, 1976
                • 2074
                Hello all
                Cheers!
                Mark
                Be careful not to try and clean the back of those original T3's as the ink stamps are fragile and wipe off easily..to be lost for ever. It is nice for you to know that you have the originals to your car.
                The schematic provided is a portion of the actual blueprints that were given to me by an engineer at the supplier. They supplied me with both full size and reduced size prints many years ago and a history of the T3's.
                I can't remember if I posted the shematic for the earlier big bulbs or not. A project for another day.
                Congrats on your find.
                Joe
