Late Production 67's - NCRS Discussion Boards
  • Ralph P.
    • February 1, 1990
    • 253
    Reference a very late june 400 car, what are the changes you would expect to see from earlier production? ie... Nolen's book indicates possible trim ring & T3 headlight difference ( 68 style ? ) ... Also, the 3917215 heads with untapped temp. boss.
    My car also has a straight handle hood release instead of the curved version.... I have no idea of originality .
  • William L.
    • December 1, 1988
    • 944
    Re: Late Production 67's
    Ralph
    I have a late 67/435 Body build date of 23 June 67, vin# 21683. It's mostly original about 90% of the parts on the car are the parts it left the factory with. The T3's are clear field type. when I bought the car it had two the 2 styles of trim rings but I didn't want to fight with the judges so when I had it judged I made sure that it had 4 of the "correct" 4 clip style on it. My car has 3904391 heads. Hope this helps? If you need any more info call me at
    314 795 1967.
    Bill
    Bill Lacy
    1998 Indy Pacecar
    • William L.
      • December 1, 1988
      • 944
      I had to go look at the hood release, it's the curved.
      Bill Lacy
      1998 Indy Pacecar
      • Dale S.
        • November 12, 2007
        • 1224
        March 30th curved. Dale
        • Ralph P.
          • February 1, 1990
          • 253
          Thanks Bill & Dale... FYI Bill, mine's 21886 with build date of K27... Guess I'll now install the NOS curved handle !
          • Mike M.
            Director Region V
            • August 31, 1994
            • 1463
            FWIW,
            224XX had the traditional T-3's and the square hood release handle.
            HaND
            • Ralph P.
              • February 1, 1990
              • 253
              Interesting, Mike.... Do you know if your "non-curved" hood release handle is factory? Maby real late cars did have these?
              • Mike M.
                Director Region V
                • August 31, 1994
                • 1463
                No Ralph, I was not the first owner, so, there is no way of knowing for sure.
                I would however, suspect that it was original in that the second owner bought it in '68, drove it for less than two years, then it sat in a barn until I bought it in '04.
                The car was assembled two days from the end of production, the workers were probably pulling from the bottom of the bins by then.
                HaND
                • William L.
                  • December 1, 1988
                  • 944
                  HaND
                  Mike
                  Near the end of production I think a lot of strange things happen. My car was built on 23 June 67. The R/H door panel has a date of 6 June 67 but the L/H door panel has a date of 13 Sept. 66 almost a year old door panel. Go figure?
                  Bill
                  Bill Lacy
                  1998 Indy Pacecar
