Hi everyone!
I'm reinstalling the interior guts on my 67 roadster.I put the dash panel back in last Sun.Everything works beautiful.All the fuses are fine & my rear running lights & front also are working fine,but NO brake lights when I hit the brake pedal & then last night I noticed that my interior courtesy lights would not shut off----strange????The only thing I can figure is that the steering column needs to be re-installed & plugged back in to basically complete any & all interior electrical lighting connections,as the column ties-in with the rear signal lights to make them operate & perhaps complete some sort of circuit loop that will enable the brake light to work!Luckily,all the wires underneath have never been tampered with & I put a voltage tester on the orange & white brake switch wires last night under the dash/column mount & they "HAD" juice!
Any ideas????
Thankyou----------Fred
Any ideas????
