63 Reproduction knock-off wheels question - NCRS Discussion Boards
  • Tony B.
    • December 2, 2008
    • 6
    I have a set of reproduction knock-off wheels for my 63 that have oxidation on the machined surfaces of the wheels. My question is: Is there any way to remove the oxidation and restore the surfaces to their original luster?
    Re: 63 Reproduction knock-off wheels question
    Have you tried the ALUMINUM form of Naval Gel? Most hardware stores stock the pink Naval Gel intended to dissolve rust (iron oxide), but there's a second version (blue color) that's made specifically for aluminum oxide...
    If they don't have it, most can order it up for you!
    • Bill C.
      • May 31, 1989
      • 424
      Triple 000 steel wool and some light oils, then some never dull polish, both available in your loacal walmart
      • Tony B.
        • December 2, 2008
        • 6
        Thank you both for the suggestions....
        • David D.
          • January 1, 2005
          • 416
          Tony,
          Let us know which method works best for you. I have a similar problem and would like to know your results.
          David
          • Tony B.
            • December 2, 2008
            • 6
            I'll let you know next week. I'll be at the Kissimmee meet this weekend and will work on them next week.
