Gm Axle Number 66 Vette - NCRS Discussion Boards
  • Harry L.
    • December 22, 2008
    • 370
    Gm Axle Number. I Guess That Is What It Is Called. It Is At The Bottom Of The Differenial,in The Center Below The Leaf Springs My Number Reads Gm 8871876. Can Anybody Give Me Any Meaning Or Information About This Number?
    Re: Gm Axle Number 66 Vette
    Harry -
    Sure it isn't 3876476? That casting number should appear on the passenger side of the differential housing, just above the "fin" and rearward of the input yoke.
    • Wayne M.
      • March 1, 1980
      • 6414
      Harry -
      John -- I'll bet Harry's reading the (upside down when installed) rear cover casting #, 3871375, with the numbers '3' looking like '8's and the '6' like a '5'.
      When he said 'center below leaf spring' (if unit was inverted), I thought of the rear cover number possibility.
      • Harry L.
        • December 22, 2008
        • 370
        John you have the right location upside down at the bottom of the rear casing, it is not the number on top of the differential .I will have to check the number againthanks!
