1968 Door Upper Hinge Covers: What Color? - NCRS Discussion Boards
  • Russ T.
    • May 31, 1989
    • 113
    I need help in determining the color of the upper hinge cover plates on the
    inner door that cover the door attachment bolts. Are they supposed to
    be the same as the body color?
    This cover is P/N 3919667-8 and sticks out from behind the door panel,
    so it can be seen when you open the door.
    Was this cover attached after the car was painted? Right now it is black
    with the body color (blue) underneath it.
    Russ
    • 15573
    Re: 1968 Door Upper Hinge Covers: What Color?
    The early 1968s had this panel painted body color. The blackout on them started later, but off the top of my head I can't remember if it was late 1968 or early 1969 for the start of the blackout. I would bet the 1968-69 TIM&JG has the answer, but I don't carry that to work with me.
    It might be helpful if you told us the approximate build date of your car. Someone might know the change point from memory or experience.
    • John C.
      • January 1, 2005
      • 616
      Russ
      The hinge cover should be painted body color. It was already installed on the car when it was painted.
      As Terry says they started to blackout this area late in the 68 model year so the body color would not show through to the inside of the car. The judging guide makes no mention of exactly when it started. My April built car does not have it. Original factory blackout would cover the entire door jam area and not just the cover.
      John
      • Russ T.
        • May 31, 1989
        • 113
        Car is #1501, built date October 5, 1967.
        Russ
          • 15573
          That early -- body color. Someone thought black would up-date the look.
          • Jack C.
            • September 30, 1992
            • 1090
            My early 68 #9643 (Jan, 22) is painted body color.
            Jack Corso
            1972 Elkhart Green LT-1 Coupe 43,200 miles
            Top Flight 1994, 2018 & 2021
