Teak Or Walnut - NCRS Discussion Boards
Teak Or Walnut
  • Todd L.
    • August 26, 2008
    • 298
    Teak Or Walnut
    What wood was used in a 74', Teak or Walnut?
    Todd
    • 11608
    Re: Teak Or Walnut
    Todd
    Todd,
    For what part?
    Steering wheel? Door and dash trim?
    Steering wheel is "neither."
    Dash and door trim is not teak. I suspect it's another hardwood; walnut may be a reasonable guess.
    Patrick
    • Todd L.
      • August 26, 2008
      • 298
      Re: Teak Or Walnut
      The wood is for the doors and the shift console. I have the deluxe interior, all the part catalogs have teak and walnut listed but they do not specify a date.
      Todd
        • 11608
        Re: Teak Or Walnut
        Todd
        Todd,
        Corvette Central only shows walnut, but Zip and Doc Rebuild (can I put them in the same sentence? ) both show teak as 1976 only.
        Also, I do not believe that any of the replacement wood pieces currently available (unless they've changed very recently) are anything like your originals. If you have originals in reasonable condition you are better off restoring them than replacing them. Most replacements are esentially "wood looking shelf paper" stuck on a metal backing, not real wood.
        Patrick
        • Todd L.
          • August 26, 2008
          • 298
          Re: Teak Or Walnut
          Unfortunately the wood is missing from the door plates, if you know a way to restore the wood on the shift console, I am all ears.
          Todd
          • Wayne W.
            • April 30, 1982
            • 3605
            Re: Teak Or Walnut
            Todd,
            Zip and Doc Rebuild (can I put them in the same sentence? )Patrick
            Only if you dont use illustrations.
              • 11608
              Re: Teak Or Walnut
              Todd
              You can remove it very, very carefully and then refinish it. If you're nervous, find someone in your area who refinishes wood and let them do it - it won't be expensive.
              If you do wood, I know people who have used a thin veneer to reproduce wood trim in Corvettes.
              Patrick
              • Todd L.
                • August 26, 2008
                • 298
                Re: Teak Or Walnut
                Thanks, it's looking like the wood is walnut.
                Todd
                • Reba W.
                  • 932
                  Re: Teak Or Walnut
                  The 1970-72 JG describes original woodgrain and also the problem with the repros. I believe the later cars were the same.
                  • Kenneth T.
                    • March 23, 2008
                    • 631
                    Re: Teak Or Walnut
                    I have a '71 with dark saddle, walnut trim. The '70 thru '72 cars I have seen have similar wood trim on the panels, not exact as they are real wood. I have seen later cars with a much lighter wood trim that does not have the grain and color of the earlier cars. Look online at wood veneers
                    and you will see the difference between the walnut and teak. I am posting a picture of a walnut trim piece. I don't have a teak one for comparison.
                    You can buy thin wood veneer and choose the grain and color and cut them out to fit your panels. The formica repros are...well, not.
                    Ken
                    • Dick W.
                      • 10483
                      Re: Teak Or Walnut
                      Once upon a time, there was a member that had access to a cnc laser that was going to make some panels. I do not remember who he was or have not heard anything further
                      Dick Whittington
                      • Kenneth T.
                        • March 23, 2008
                        • 631
                        Re: Teak Or Walnut
                        Dick,
                        When I can get away from business; I have a template I made and will try to cut out the veneer with a router and sharp bit. I will let you know of my progress.
                        • Dick W.
                          • 10483
                          Re: Teak Or Walnut
                          That is gonna be a trip! I bet the original veneer is not over 1/32" thick. Lotsa luck.
                          Dick Whittington
                          • Mike M.
                            Director Region V
                            • August 31, 1994
                            • 1463
                            Re: Teak Or Walnut
                            Dickie, right on. The wood may be less than 1/32" thick.
                            The real problem is that the wood is actually glued to a simarlarly thin piece if aluminum (If I remember, or some kind of metal). Trying to get that off of the door or separated from the metal or re-straightend to lie flat on the door panel is nearly impossible.
                            On one car I was lucky, the piece just fell off. I refinished and reapplied.
                            The second one was so mangled that I started with new material. I found a machine shop that had enough of a piece of scrap aluminum for the base and a woodworking friend with a left over piece of walnut veneer, I used the original as a pattern to trace the metal and cut the wood with an X-acto knife, touched up the radii with sandpaper, finished and re-applied.
                            Good Luck
                            Roll up your sleeves and HaND
                            • Dick W.
                              • 10483
                              Re: Teak Or Walnut
                              For the enterprising member out there, I found this veneer at Wood Workers Supply. It is 5 mil thick. http://woodworker.com/cgi-bin/FULLPR...3&LARGEVIEW=ON
                              Dick Whittington
