I know that the RPO 687 had the large "cups" on the bottom of the small brake shoe hold down springs but were they on the RPO 684 cars? I havn't heard of them being present on the early big brakers but what are your opinions? Thanks guys!!
RPO 684/687 Differences :The Details
Re: RPO 684/687 Differences :The Details
Not exactly sure what you want here Justin, but I received the following from Fran Estereicher, Corvette collector that loves RPO brake/ suspension stuff and has access to GM Engineering from the 50's and 60's.
I attached the spring picture. does that help?
Co-Founder REGISTRY OF CORVETTE RACE CARS.COM- Top
Here they NOS.
Same size and dimension as standard pull back springs but these are high heat treated...and painted dark green.
JoeAttached Files- Top
Jim
I don't know by the picture..I would have to check the part # in an old parts book. Just a guess but it appears to be a genuine spring kit. Not sure of the application.
Joe- Top
Thanks Guys,
I learned something here. Back in the day no one looked, we just changed the parts. Doug Hooper and I were talking last week about this. After each day of racing it was not uncommon to completely do a 'new brake job' at the race track.
NEW shoes, NEW Springs, and NEW drums. We even rebuilt wheel cylinders. A major RPO set up came in a wooden box for $202.00. And as I remember, there were springs and a quick steer adapter in there also.Over 80 Corvettes of fun ! Love Rochester Fuel Injection 57-65 cars. Love CORVETTE RACE CARS
Re: RPO 684/687 Differences : SPRINGS
SPRINGS very boring subject, unless you were a spring designer in a previous life.
- Top
Franz, good to see you in Florida. Would you give a lesson on measuring brake spring tension. I do have fish scales. Also why was the small spring used for the race RPOs and the large springs used for the street metallic RPO.
Regards- Top
- Top
Hi John:
- Top
Franz..If memory serves me correct the fronts are cast iron and the rears are aluminum..or vice versa.
Next time I get a chance I will look. The car has less than 50,000 miles but I did have a brake job...so who knows if they replaced the springs.
Hope you are well..
Joe- Top
