Trying to figure out what some specs for a '60 283 w/single WCFB carb should be.....We seem to have about 3 different numbers and need your expert help in determining what is correct.
We already have the Lars documents but we also have Corvette Service guide and other info, so that is where there is confusion. Would like real numbers if possible.
1) What is timing supposed to be at idle? 4 BTDC or 18 BTDC ?
2) What is Vacuum supposed to read at idle? 18-20" or <6"
3) What should RPM's be? 475 rpm or 700 rpm
with or with out vacuum advance connected?
4) At what rpm or HG vacuum should vacuum can kick in?
5) What rpm or HG vacuum should full in be at?
Any other numbers that we should pay attention to would be appreciated.
FYI-Current idle readings currently around 700rpm at 18 BTDC but vacuum around 6" flucuating badly.
David
David
