My HB goes on fairly snug but without an interference fit. The snout has an outside diameter of 1.245 and the HB has an inside diameter of 1.2455. This extra 1/2 thousands is making it slip on.
Since I had my snout drilled for a grade 8 bolt would it be OK to install this HB ?
Should I consider using anything to keep it snug like a Loctite product ?
It was already balance with my engine so I am hoping I can still use it.
Does my crank snout seem to have the sizes outside diameter ?
