Harmonic Balancer depth - 1960 - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 934
    Is it normal for my HB to be installed against the spacer and still have 1 and 1/8" of travel left before the snout would reach the front of the HB ?
    My machine shop installed a Cloyes 9-3100 double roller chain. Is it possible this is pushing the HB forward some ?
    With the spacer installed the snout is 1 and 1/8" long and the HB bore is 2 and 1/4" long.
    Re: Harmonic Balancer depth - 1960
    Mark-----
    If I'm understanding you correctly, what you describe sounds normal to me. The thickness of the crank sprocket on the Cloyes 9-3100 is the same as stock. So, the Cloyes sprocket, IF INSTALLED PROPERLY, should cause no problem with installed position of the harmonic balancer.
