70 L46 Valve Covers Aluminum or Steel? - NCRS Discussion Boards
  • Ernie F.
    • March 31, 1975
    • 107
    70 L46 Valve Covers Aluminum or Steel? I'm out of town and don't have a JG. I always thought the low horse was steel, am I wrong?
    Ernie
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 70 L46 Valve Covers Aluminum or Steel?
    You are correct, 1970 350/300 valve covers were steel. To get the aluminum valve covers a buyer would have to purchase an optional 350 engine, the 350/350 or 350/370.
    • Ernie F.
      • March 31, 1975
      • 107
      Jim,
      Thanks, just what I thought!
      Ernie
        Originally posted by Ernie Fry (224)
        Jim,
        Ernie
        Ernie-----
        Somehow, I think something got confused here. Jim's description of the small block valve cover situation for 1970 is correct. However, the 350 hp 350 IS the L-46; the L-46 is NOT the base engine. So, the L-46 for 1970 used ALUMINUM valve covers; the base engine used stamped steel valve covers.
        By the way, the 1970 L-46 aluminum valve covers were not the same as those used for 1969 L-46. The 1969 covers had no cast-in drippers; the 1970 did have cast-in drippers.
        • Ernie F.
          • March 31, 1975
          • 107
          Thanks Joe,
          That was my initial error, I too felt teh L46 was the base engine for some reason. . . Then I checked!
          I was not aware there was a difference in the covers. Interesting, I'll have to check to see if I have any that are different.
          Ernie
