Which Hood Weatherstripping is Correct? - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    Hi all,
    I just got back from Florida and really enjoyed the meet. I have a quick question regarding which length hood weatherstripping is correct? During my flight judging the judges said it should be shorter but two other cars besides mine were longer. One car was a true documented low low miles car with longer ends. Any expert opinions are appreciated.
    Cheers,
    Craig Willetts
  • Timothy B.
    • April 30, 1983
    • 5177
    Re: Which Hood Weatherstripping is Correct?
    Craig,
    It's always been my understanding the shorter weatherstrip went with 63 cars and later cars got a longer weatherstrip. What does the judging manual say, the shorter strip may have continued in early 64.
    • M W.
      • July 31, 2001
      • 835
      Originally posted by Timothy Barbieri (6542)
      Craig,
      Timothy,
      The judging guide only says it should come to the center of the pin. Which center are they speaking of..who knows. I only replaced my original one last year with a new one and made sure to cut it the same length before installing. The judges still said it was wrong.
      Who knows,
      Craig
      • Michael H.
        • January 29, 2008
        • 7477
        Originally posted by M. Craig Willetts (36551)
        Timothy,
        Who knows,
        Craig
        The shorter version is definitely the correct one for all of 63 and I think most of, if not all of 64 production.
        The manual does refer to the C/L of the hood pin as reference on the back of the hood.
        I don't remember exactly when the longer w/strip entered production.
        • Tom H.
          • December 1, 1993
          • 3440
          My 63 has the short version. Although restored, I've always believed that to be correct. My 65 had the long version that wrapped around the corners.
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • Alan D.
            • January 1, 2005
            • 2027
            Mar64, short strip and that's how I purchased it in Aug 67.
            • John D.
              • December 1, 1979
              • 5507
              When I bought my 63 coupe in 1979 it had the original short style rubber strip. So the first time the car was restored we goofed and used the long rubber that wrapped around the corner like the 65 up ones do.
              So when some of the car was re-restored we used the correct short one. It appears to be correct as no dings.
              • John F.
                • March 23, 2008
                • 2395
                Center of the pin is the "right" photo. Same as my 62.
                • M W.
                  • July 31, 2001
                  • 835
                  Thanks so far.
                  Craig
                  • Mike M.
                    Director Region V
                    • August 31, 1994
                    • 1463
                    Hello,
                    '63-4, Right pic.
                    '65-6, left pic, centered (Approximately) to the center line of the pin from the outboard side.
                    '67 A little longer than the '65-6 with the plastic push pin added through the inside the tip of the strip into the verticle side of the hood reinfocement.
                    Documented extremely low mileage does not guarantee originality of all components.
                    HaND
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      Originally posted by Mike Murray (25129)
                      Hello,
                      '63-4, Right pic.
                      HaND
                      That sounds about right. I always remembered the longer w/strip coming into production at around the start of production of the 65 model year, about the same time the hoods changed and the upper and lower panels were held together with flubber instead of bond.
                      • James W.
                        • December 1, 1990
                        • 2640
                        Craig,
                        Below are pictures of an original, unrestored 1964 hood on the left and an original, unrestored 1965 hood on the right, both having the correctly placed weather stripping.
                        Hope this helps.
                        Best Regards,
                        James West
                        Omaha, NE.
                        • Alan D.
                          • January 1, 2005
                          • 2027
                          Think some 67 have the plastic push pin, but others do not. Believe it depends upon where body was made. Now if a 67 expert can expand on this?
                          (I've just heard this, do not know for sure)
                          • Mike M.
                            Director Region V
                            • August 31, 1994
                            • 1463
                            All original '67's we have seen have the plastic push pins regardless of body plant origin.
                            Granted, I am aware that there are many '67's out there with pins in absencia.
                            Many things can happen over 42 years.
                            HaND
                            • Paul J.
                              • September 9, 2008
                              • 2091
                              Originally posted by James West (18379)
                              Craig,
                              Hope this helps.
                              Best Regards,
                              James West
                              Omaha, NE.
                              My early 64 original weatherstripping looks like the one on the left.
