Exhaust packing 'donut' part number - NCRS Discussion Boards
  • Jeff S.
    • July 31, 1984
    • 383
    Can anyone help with the GM part number for 2" exhaust packing seal/donut? I think the current ones are sintered metal instead of the crushable asbestos type & it is likely one of those newer 8-digit part numbers. Or, can a suitable replacement be obtained at FLAPS? Thanks.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: Exhaust packing 'donut' part number
    Jeff,
    The part number for the 2" sintered donut is 3731062.
    It is also available in 2 1/2" as part number 3767556.
      Jeff-----
      It depends what you want. The sintered metal donut packings never replaced the "soft" type. Both types are still available. The 2" "soft" packings are GM #6271611. The 2" sintered packings are GM #3731062.
      • Ernie F.
        • March 31, 1975
        • 107
        If you are ordering it from GM it comes in a 5 pack? Go figure!
        You can also purchae this in aftermarket and the composite is dead on. p/n 85000 and it should be around 1.50 per packing, packaged in a single unit.
        Ernie
        • Jeff S.
          • July 31, 1984
          • 383
          Ernie
          How would I use that 85000 aftermarket part number? That is, who uses that numbering convention? (NAPA, Auto Zone, Standard ...) Thanks.
          Jeff
            Ernie
            Jeff
            Jeff-----
            I think that's the Willcox part number.
            • Ernie F.
              • March 31, 1975
              • 107
              The number "85000" was an old after market part number, it crossed to a Felpro 8194. Rol Manufacturing took over the small gaskets from Felpro and the current part number is a EG24017. You should be able to purchase this anywhere.
              • Brad M.
                • July 31, 2005
                • 262
                I just checked the box of the ones that I installed on my car - they are the 6271611 - which was already mentioned above.
