Engine Pull Brackets 427/400 - NCRS Discussion Boards
  • Ned T.
    • December 29, 2008
    • 188
    I was told by Paragon that the rear engine pull bracket is the only one that should be on the engine. They said the front one was removed at the factory after engine installation due to the Tripower set up. Anyone know if this is correct? This is for a 1969 427/400
    • 15573
    Re: Engine Pull Brackets 427/400
    Yes, they are right.
