I currently have a 1978 Corvette Pace Car with a power CB antenna. The antenna motor works, but the mast does not move up or down. I want to keep the original metal body rather than replace it with a plastic-body unit. The usual fix is to replace the plastic antenna cable that connects to the mast.
I've purchased a new plastic antenna cable. The directions given are quite lacking. Although I've had the entire antenna apart, it seems impossible to insert the long metal end through the antenna body without bending it.
Anyone had any luck with this fix?
If not, does anyone know who can refurbish these antennas?
Brian
Brian
What a greasy mess...
