Spare Tire Tub Paint? - NCRS Discussion Boards
  • Don L.
    • August 31, 2005
    • 1005
    I'm in the process of restoring my C3 tub, and see in an archived thread that "semi gloss" black is to be used for the "V" brace on the bottom tub. I've had great success with SEM paint products, but according to my local dealer, it's only available in matte and gloss. Does anyone have a tip or advice on what paint is the best choice?
    Don Lowe
    NCRS #44382
    Carolinas Chapter
  • Jack C.
    • September 30, 1992
    • 1090
    Re: Spare Tire Tub Paint?
    Plasti-kote #361 is Semi Gloss Black
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Don L.
      • August 31, 2005
      • 1005
      Thanks, Jack. I hope I can find it and I hope it works as well as the SEM paints. That stuff is awesome!
      Don Lowe
      NCRS #44382
      Carolinas Chapter
      • Kurt G.
        • April 30, 2005
        • 343
        As an option, if you like the SEM product, get the matte, and hit it with some polishing compound until you get the desired amount of "gloss".
        Kurt Geis
        Chairman, Midway USA Chapter
        Targa Blue 1972, Top Flight and Duntov Award, 2014
        Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
        Arctic White 2013 60th Anniv Special Edition Conv.
        • Rich G.
          • January 9, 2009
          • 51
          While your on the subject of spare tires, what do you suggest for the tub itself. Its clean but has 30+ years of exposure. ( and a few scrapes)
            • 3415
            Hi Rich,
            I cleaned my tub with lacquer thinner, did a little repair where it had been scraped and then put a dusting of semi-gloss clear on it. It looks pretty nice and natural.
            • Steven G.
              • November 17, 2008
              • 348
              O.K. now I am a bit confused about 1970 spare tire tub finish. I am pretty sure the metal v brace is painted semi gloss black. Should the fiberglass tub be painted semi gloss black or natural fiberglass finish? I was thinking there may be black out on some areas of tub. Could someone add their openion? Thanks
              • Jack C.
                • 1090
                I believe it's natural with maybe some undercoat on it from the factory. Use WD-40 to refresh the fiberglass look.
                Jack Corso
                • Don L.
                  • August 31, 2005
                  • 1005
                  The polishing compound sounds like a good idea. My local paint store manager suggested a coat of SEM clear semi gloss over the matte SEM paint, which I had been considering.
                  As for the WD 40, wouldn't this leave it attracting road dust, etc?
                  One more thing. When I removed the "V" brace, I found a very nice, clean Rockwell decal in tact. I had not seen these UNDER the brace before. Has anyone else found one there?
                  Don Lowe
                  NCRS #44382
                  Carolinas Chapter
                  • Michael G.
                    • March 2, 2008
                    • 485
                    Yes Don,
                    My 71 has the label also in the indented slot that the bracket goes. The WD-40 would be a good solvent for the removal of the black overspray, but would definetely attract dirt if not removed. I found a product ( I think it was Turtle wax Ice) that was designed for the treatment of plastic pieces. Works well with no residual to attract dust.
                    Best of luck, Mike
                    • Chuck S.
                      • April 1, 1992
                      • 4668
                      It's a date code tag, with the date being in a week/year format WW-YY.
                      Date decals on spare tubs are not uncommon, but not all the tubs have them. Existence of date code tags on other fiberglass panels is much more consistent in my experience. It's location UNDER the brace is coincidental...you can see them anywhere on the bottom of the tub. If the date precedes your car's build date by several weeks, it's likely the original; if not, then the date can't be seen anyway.
