Distributor Cap for 63 - NCRS Discussion Boards
  • Jeffrey A.
    • October 22, 2006
    • 273
    I have a 63 coupe with a 327/300hp powerglide. I have been trying to locate the correct distributor cap for my car. The JM explains the the cap should be black and have the wording "Patent Pending" Attached are a couple of cap I had found not have not bought. Can anyone tell from the or the pictures I have posted if either of these would are correct for my car. If not, is a place supplier I could contact whom might have would I am looking for. Thank you - Jeff
  • Jeff A.
    • January 1, 2000
    • 312
    Re: Distributor Cap for 63
    The first cap "Patent Pending" is correct through 68.
    The second one with the R is 69 and later.
    R was used for the resister plug applications.
    The even later caps have a patent number on them.
    My Cars
    • John D.
      • December 1, 1979
      • 5507
      Jeff, You need a D308 black cap. D308 has the hi towers. D310 has the low towers. Only FI used the low tower cap. As mentioned your cap should have Patent Pending Delco Remy on the top. NO R. Aluminum contacts. Some think these caps are rather dull in appearance but when new in the box they were quite shiny.
      Also some find it necessary to zip off the R on a service replacement cap so as not to be hit hard on the judging floor.
      All 63 to 65's used a black cap. You didn't ask but here is one for all of you. The 64-65 TI;s used a black cap. Not a brown cap. The brown caps were for L88 and trucks and also service replacements.
      This D308 cap came out around 1955 on Olds and Buick, etc. John D
      • Jeff A.
        • January 1, 2000
        • 312
        The 309 cap with the brass contacts would be perfectly acceptable for judging.
        No one could ever tell when installed.
        NCRS is not pulling wires yet are they?
        I have a very large collection of these caps I have saved over the years.
        My Cars
        • Mike M.
          • May 31, 1974
          • 8365
          original delco caps have a "ledge" on the rear vertical wall of the door jamb(the opening for the "door" that allows setting the points without removing the cap). BTW, the fellow that thought up the open door dist cap, Jim Kerr, had a garage here in cumberland in the early 50's. GM never compensated him for the invention. The current repo dist caps lack the ledge on the door jamb and its absence is easily felt by running youir finger along the door jamb. mike
          • Jeff A.
            • January 1, 2000
            • 312
            Also on the repro caps the Delco script is not as "pronounced".
            Over the years it appears the molds became worn - the later caps with the patent numbers have a much less depth to the Delco script.
            This seems to be what was copied for the current reproduction.
            Compared to the early original caps it is very evident that the repro is being used.
            Again - the repro feels different then an original.
            My Cars
            • Paul O.
              • August 31, 1990
              • 1716
              Jeffrey I have looked at a lot of Caps there are 5 308 caps that I have seen first
              1. Patent Pending no R
              2. Patent Number no R
              3. Patent Pending R
              4. Patent Number R
              5. No script on top
              That for the 308's for 309, 310 would have the same Patent procedure . For me that is what I think is true but other judges may see it different. From talking with a Patent Attorney he stated that the Pending would be for a limited time due to the patent office issuing a patent number for that item then that patent number would be installed till there was a change to the design which would start the whole process over again. Hope that helps Paul 18046
              • Jeffrey A.
                • October 22, 2006
                • 273
                Paul/Jeff/Mike and Tom
                thank for all the information regarding the correct dist cap for me 63. This make it clearer for me in my search. Thanks - Jeff
                  Thinking something up, isn't where the rubber meets the road in science & engineering! You can't patent an IDEA...you need to submit a 'brass board' and demonstrate your proficiency in the field relative to existing current art (e.g. you understand and can control the technology).
                  The lift window feature of the distributor cap is part of US Patent No. 2,769,047 which was filed on 12/23/53 and granted on 10/30/56. The inventors are listed as: Herman L. Hartzell, David C. Redick, and Clarence L. Julian. There's no mention of James Kerr and nothing in the records of his having filed a legal contest of GM's intellectual property rights...
