Hi Folks - I'm collecting part numbers for a '66 L-79 rebuild. I'm also collecting the same info for a '67 L-79 since that rebuild will follow shortly after the '66.
Oddly, I find different p/n's on the F-M website for the two years: KT3-489S (w/223-261 cam sprocket) for '66 and KT3-499S (w/0.405" tooth width 223-390 cam sprocket ) for '67. Since a 223-390N nylon toothed sprocket is listed separately for '67, it appears the difference between the "sets" is NOT the nylon teeth....
Can anyone explain the difference? ....is there a difference in tooth width? .....or single vs double row?
TIA
Bob.....
TIA
Bob.....
