can any one give me an ID and specs and use of this fly wheel? ex diameter clutch size and tooth count? bill
3781021 Flywheel L79?
Re: 3781021 Flywheel L79?
William, this is the standard small diameter flywheel and had a part number of 3791022 with casting number of 3791021. Are you sure yours is an "8" instead of a "9"?
My parts catalog(Sep'71) lists this flywheel for 63-68(283,327) (exc. A.T. H.D. Clutch)
Being the smaller wheel it has 153 teeth and drilled & taped for 10.5 clutch- Top
Tom------
Yup. And for some unknown reason, GM seemed to "alternate" on the use of the two sizes between generations of Corvettes. To wit:
C1----All 14", 168 tooth
C2----Mostly 12-3/4", 153 tooth (except 66-67 with L-36, L-72, L-68 and L-71)
C3----Mostly 14", 168 tooth (except 68 small block, all L-88, and ZR-1)
C4----All 12-3/4", 153 tooth
C5/C6----All 14", 168 toothIn Appreciation of John Hinckley- Top
Tom-----
All L-88 (and ZL-1) with manual transmission used a 12-3/4", 153 tooth flywheel. No PRODUCTION L-88 ever used a dual disc clutch although that seems to be a pretty widely held belief. The only applications that ever used the dual disc clutch were as follows:
1969 with L-71 and MA-6 HD clutch option
1971 all LS-6 with 4 speed
The dual disc clutch used a special 14", 168 tooth flywheel, although it used 10" friction discs.In Appreciation of John Hinckley- Top
Joe,
I could cut off 3 fingers from one hand and count all the GENUINE L88 cars that I've seen in person on that one hand. But, I never crawled under them to check the size of the bell housing (which would indicate flywheel size).
Also, I've always understood that the HD dual disc clutch was a 10in clutch, but I've never actually had one in my hands. Soooooooooooo, if the dual disc clutch was mounted on a 14in flywheel, did it use the same bolt pattern as a 10.4 pressure plate, or an 11in pressure plate?
Furthermore, if the L88s and ZL1s only used a 153 teeth flywheel (I'm guessing the lightweight version), then that means they could have ONLY had the 10.4 clutch. Right?- Top
Next best thing to having one in your hands -- a pic.
This is from "How to hotrod BB Chevs" 1971.
There's also a Chev profile design drawing of the complete flywheel, disc plates, cover, T.O. bearing and fork, and bellhousing in the "1969 New Product Training Program Booklet".Attached Files- Top
Joe,
Tom-----
If you find any bellhousing on an original L-88 Corvette that's not a GM #3858403 (or, POSSIBLY, a GM #3840383), then it's not the one that was originally installed on the car. All L-88 and ZL-1 with manual transmission used a lightweight 12-3/4" flywheel, GM #3866735, and 10.4" clutch. However, not all L-88 and ZL-1 were equipped with a manual transmission. All 1967-68 were but for 1969, some L-88 and ZL-1 were equipped with a special THM-400. Those applications used a 14", 168 tooth flexplate.
The 10.4" clutch used for L-88 and ZL-1 was not the same as that used for 63-68 small blocks. L-88 and ZL-1 used a HD pressure plate and disc of GM #3886066 and GM #3886059, respectively. While the L-88 and ZL-1 flywheel was also used for 1965 L-78, the same pressure plate and disc were not used for 1965 L-78. The only other applications for the pressure plate was 1970-72 ZR-1 and the only other application for the disc was 1970 ZR-1 (although 71-72 ZR-1 used a similar disc but with 26 splines).
The dual disc clutch used a special 14", 168 tooth flywheel that was drilled for the special size of the 10" dual disc pressure plate and cover assembly. This flywheel was not used for any other application except 1969 with MA-6 and all 1971 with LS-6 and manual transmission. 1969 with MA-6 is the same as all 1971 LS-6 with manual transmission EXCEPT the dual discs use 26 splines rather than the 10 used for 1969 MA-6.In Appreciation of John Hinckley- Top
