1963 Coupe Windshield Moulding Clips - NCRS Discussion Boards
  • Gene K.
    • August 31, 2006
    • 34
    Does anyone know where to purchase the correct fitting Windshield Moulding Clips for a 63 Split Window and how many there are?
    Thank you, Gene
  • Paul Y.
    • September 30, 1982
    • 570
    Re: 1963 Coupe Windshield Moulding Clips
    There are 13 on the top moulding and 15 on the bottom. Non on the sides as they are slid into the top and bottom and have screws holding them on. Do you know where they are located? I might could post a photo later if you need it. I don't know where to find some repos but I'm sure someone on here knows.
    It's a good life!
    • Timothy B.
      • April 30, 1983
      • 5177
      I remember seeing them in the Paragon book. I am not aware of any screws holding clips on a 63 coupe windshield frame. The corner clips slide into the side revel moulding corners and are attached into the regular clip that is attached to the windshield frame, top and bottom. I believe the top/bottom and caulk are how the side mouldings are attached.
      The windshield clips have six that are wider where they slide over the three thickness windshield frame and the others are for the two thickness metal frame. Once you have them in your hand and look at the frame it becomes obvious because they are the same except for the wider area for the windshield frame.
      • Jack U.
        • November 1, 2003
        • 212
        I got mine over three years ago from Corvette Pacifica. It was the last set that they had at the time.
        • Paul Y.
          • 570
          I humbly apologize for my lack of eloquence in communication skills. The big mouldings in the sides slide over the upper and lower moulding of the windshield and are held in place by four screws on the door side of the windshield post. I have attached photos but they are not very clear. I trust that they are helpful. Paul
          It's a good life!
          • Paul Y.
            • 570
            Here's one without the moulding in place. Looking closely you might be able to identify the screw holes.(one on top of the light line and three below)
            It's a good life!
            • Jeffrey A.
              • October 22, 2006
              • 273
              Gene
              I bought my clips from Paragon for my 63. They worked and fit perfect.
