What correct clamps and color of clamps goes on a 1970 Corvette LS-5 with AC and power steering and power brakes?
1.) PCV hose on both ends? Pinch clamps?
2.) Brake booster hose on both ends?
3.) Power steering hoses?
4.) Fuel pump hoses?
5.) Brass overflow tank hose?
6.) Brass overflow tank to radiator hose?
7.) Both ends of the air cleaner to passenger side valve cover? 1-1/2" dated tower clamps?
I think I'm clear on the type of clamps on the two heater hoses to the water pump and intake and the hose to the underside of the overflow tank. Dated tower clamps of sizes 1-1/16" and 1-3/16".
The JG seems to have them depicted or mentioned on several different pages or no mention of hose clamps at all but after I've read archive discussion after discussion there seems to be running differences in hose clamp applications in some areas.
Scott Sims
Texas Chapter
Scott Sims
Texas Chapter
I have learned that geared clamps were not used and the clamps that were used will cause a person to bleed, so that's why they were replaced with geared clamps over the years. Steve
