Have the L-36 out of the 66 now thanks to the great assistance of many members here.
1) My car has undercoat/tar on pass firewall over halfway to steering column then turns to red oxide and blackout. The undercoat is thick black tar from under body lip down behine bellhousing. When it received its Top Flight it was never deducted, but I'm don't think it is right. The entire under car when I bought it in 2004 had Luby Chevrolet dealer undercoat under fiberglass front to back. I spent 3 mos taking this tar off and even found my 198 Job code #'s under pass foot well. If this firewall tar is not factory correct - should i remove it??
2) Now that the engine, rad, shroud, etc is out for the first time. Beyone the obvious frame clean-up and detail, What should a person replace now that everything is accessible, ie I see allot of rubber bushing that are dried and cracked. Best advice please.....
