On my newly aquired 72 LT-1 engine the freeze plugs had been changed out to Dorman Products brand plugs around 1975 when the engine was pulled. What would be the correct type/brand to replace with? Also it's been at least 30 years since I replaced a freeze plug, what is the correct method of removal and replacement? Thanks.
72 LT-1 Freeze Plugs
Re: 72 LT-1 Freeze Plugs
The original steel core plugs had no brand or marks on them. Your challenge will be to find some without marks.
I have never replaced one. I guess I just have missed out on that experience. I have lead a rather sheltered life, mechanically.
Small block Chevrolet engines, like your LT1, are the same back to dirt. If you did it years ago, it hasn't changed.
Terry- Top
John-----On my newly aquired 72 LT-1 engine the freeze plugs had been changed out to Dorman Products brand plugs around 1975 when the engine was pulled. What would be the correct type/brand to replace with? Also it's been at least 30 years since I replaced a freeze plug, what is the correct method of removal and replacement? Thanks.
Punch the freeze plug INWARD at the bottom. That will cause the upper edge to pivot out. Grab the upper part with channel lock pliers and "wiggle" it out.
Use BRASS freeze plugs. If there are any markings, you can "obliterate" them with a little JB Weld, dressed out after curing. After painting the engine block, no one will know the difference except a judge with a magnet. If that bothers you, use steel plugs and "obliterate" any markings in the same manner.In Appreciation of John Hinckley- Top
Thanks Joe & Terry. I did do it 30 years ago...problem is, it was 30 years ago
. I knew the original ones didn't have markings on them and these do say Dorman Products on them. I would like to find some plain looking ones if possible. As I remember I should use some sort of sealer on the rims of the new freeze plugs before reinserting them. I think I used a large socket to tap on to drive them in with...does that sound correct?
Appreciate your responses.- Top
Sounds right to me. I think Joe's suggestion of brass is the best solution. No corrosion in our lifetime with brass -- even if you put the engine in your boat. If the engine is out of the car the socket is the best method. There is a tool for setting core plugs in the car, but it only elaborates on a socket and allows for the sometimes-limited access of the chassis.
I'm not sure what sealant to use, but someone will offer a suggestion or two or three.Terry- Top
Sometime in the '90s -- before the iron block went away for any Chevrolet application -- Flint began to install brass core plugs. I recall receiving some documents from them that detailed the change. To the guys at Flint that was a very big deal. Those papers should be at the AACA Library in Hershey, if someone is interested enough to seek them out.Terry- Top
John-----Thanks Joe & Terry. I did do it 30 years ago...problem is, it was 30 years ago
An appropriate-sized socket makes an excellent driver. Also, bearing race driver tools will work well (and, keep you from beating on your sockets).
Any good sealer will work on these. I've always used Permatex non-hardening sealer. However, I think that silicone RTV will likely work as well.In Appreciation of John Hinckley- Top
John-----
Yes, they have "alternate" uses. They are not too expensive, either.In Appreciation of John Hinckley- Top
John,
If you find you are having trouble driving in the new freeze plug, leave them in the freezer for a few hours. When you are ready, remove one, put your sealer on and drive it right in. It helps to make the job a little easier.
Dennis- Top
Is that why they call them freeze plugs?
Just kidding, I jut came in from the garage replacing the one under the rh mount, in car. High patience quotient required, but got it.- Top
