Dash Cluster Codes - NCRS Discussion Boards
Dash Cluster Codes
  • Howard P.
    • May 20, 2008
    • 67
    Dash Cluster Codes
    Is anyone aware of a published listing for Dash Cluster Codes and what codes are applied to which combination for various C-2 years, particularly 67 ?
    My 67 427/435 is coded LB
  • Dan M.
    Infrequent User
    • May 31, 1988
    • 23
    Re: Dash Cluster Codes
    If you look in the long island corvette supply catalog there is a section with decals and stickers.(Dash?) you should be able to find the info your looking for.
    • Dale S.
      • November 12, 2007
      • 1224
      Howard, I could not find what you are looking for in the Long Island Corvette catalog. I found sticker's but they do not give the codes. Maybe someone else will try to be a little more helpful. Dale
      • Dan M.
        Infrequent User
        • May 31, 1988
        • 23
        Try section #2, and go down to dash cluster stickers. These stickers have a two letters to show what hp guages are in the car. might look on line and see if they show a pic. just got one for my 67 400 hp. hope this helps.
        • Wayne M.
          • March 1, 1980
          • 6414
          Just checked the Long Island section#2 list mentioned by others; see no actual sticker codes, just the code to order for different years and engine combos.
          I know that for 1965 MY, there's LA, LB and LC for base and 300hp; L76 and L78 and L84; and the last for L79. Depends on oil pressure gauge and tach redlines. Gets more complicated in 1967 MY with the addition of speedwarning.
          Here's mine from a late production (Aug 2nd 1965) 396. Also an ink stamp on cluster shell with: (top line) PACKED BY; (second line) JUL_26___1965_02. Must have been just-in-time inventory .
          • Howard P.
            • May 20, 2008
            • 67
            Thanks for the info and feedback. I'll also keep you folks posted on any other information that I may learn
            Regards
            Howie
            • Tom R.
              • April 7, 2008
              • 135
              My 67 cluster sticker is an LG and also a 427x435. Never thought anything about it until your post. The date stamp is OCT 17 1966 Q__
              CLUSTER 6459495
              SPEEDO 6458624-W
              TACH. 6468501-W
              AC-MADE IN USA
              • Richard C.
                Infrequent User
                • 9
                We have researched the codes and are selling the labels. They are listed in the catalog in section 2 part 18 as noted ... we do not publish the numbers. order by year and engine speed warning or no speed warning.
                Thanks. LICorvette
