I was getting a horrible squeaking noise which I thought was the power steering pump or a pulley. Turned out to be the tach cable. I disconnected the cable at the distributor and ended the noise. I understand that I need to pull the driver's side dash to access the back of the tach to remove the cable. Is there any other way to clean and lube the cable in place? Also, what lube; wd40? If I get the cable out; should I try and clean and lube or just buy a new one?
Don
Don
Good Luck.
