C2 Knock off Wheels - NCRS Discussion Boards
C2 Knock off Wheels
  • Robert T.
    • May 31, 1993
    • 346
    C2 Knock off Wheels
    Could someone please post, or email me, a picture of an original knock off wheel without the cone or spinner attached. I'm most interested in the wheel structure that would be hidden under the cone. I'm having a "discussion" with a manufacturer of new repro wheels regarding his cone to wheel fit. He says that the edge of the cone should butt up against the inner edge of the wheel. Kind of an edge to edge fit. I'm trying to tell me that the original design structure of the wheel would not allow that, and that it would force the cone to somewhat shroud the wheel's innner lip. Hope this makes sense.
    Thanks for any help you can offer.
    Bob
    Re: C2 Knock off Wheels
    Bob -
    Couple of photos below of original KO wheels.
    • Mark F.
      • June 30, 1995
      • 60
      Bob, hope this helps too
      • Robert T.
        • May 31, 1993
        • 346
        Thanks for the quick replies, John and Mark. Hopefully this will convince the supplier that he has a problem.
        Thanks again.
        Bob
        • Wayne M.
          • March 1, 1980
          • 6414
          Bob -- there's another "cone fit / appearance" issue. At the interface groove between the spinner and the small end of the cone, on originals, the angle changes sharply to horizontal. Whereas, on SOME repros, there's a more gradual radius. This can be seen even when the spinner is mounted. This was discussed some time back (around end of May 2008); link below. One pic shows original '66 opening / lip.
          https://www.forums.ncrs.org/showthre...60849&uid=8011
          • Robert T.
            • May 31, 1993
            • 346
            Thanks for the additional info, Wayne. The more, the better. Thanks.
            Bob
