55 trunk liner screws - NCRS Discussion Boards
  • Don S.
    • February 1, 2000
    • 476
    I believe that the trunk liner screws should be clutch head screws with a rounded type washer. I can find no reference to confirm it either in Noland Adams book or in the judging manual. Am I correct in the type of screws and washer and where can I find the definitive answer.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17549
    Re: 55 trunk liner screws
    Don, trunk cardboard - division panel should have #10 clutch head screws into the metal on the sides and #10 phillips into the fiberglass. Both have a countersunk finish washers same type as the interior door panels have. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Roy B.
      • February 1, 1975
      • 7044
      The four side screws are clutch head with round washers , the two for the jack handle are also, the bottom are Phillips with round washers,the two holding the jack bar are Phillips.
      None use the countersunk washers like the door panels .
