Re: Motor Oil
Tom------
What I don't understand about this is even if all of the zinc high pressure additives had been removed from motor oil (and, I don't think they have been for either "S" rated gasoline service or "C" rated diesel oils), all one would have to do to restore them is add some EOS or equivalent to each oil change. I think that adding about a quarter of a pint of EOS would provide more of the additives than was present in oil even in the 60's. Of course, I'd use a lot more than that for engine break-in, but after that period, just a few ounces should be enough even if there was no additive in the substrate motor oil.
So, as I see it, the most that anyone would have to do is add a little EOS or equivalent.
Tom------
