Generator Arm Trivia C1 - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    #61
    Re: Generator Arm Trivia C1
    The brace Trybulec shows on the 57 is the same as the 55 engine pic I posted , if you do find a number it will be 0364 or not ,it still will not have 3704884 on it , that's the order number. I will be thrilled to be wrong and admit it if some one could show me a number of 3704884 in the part. The 0364 brace is a first design superceded by a second design that used the same part number when ordering the brace.
    Many parts were changed in design but when ordering the part the same order number stayed the same.
    • Michael H.
      • January 29, 2008
      • 7477
      #62
      Originally posted by Roy Braatz (182)
      The brace Trybulec shows on the 57 is the same as the 55 engine pic I posted , if you do find a number it will be 0364 or not ,it still will not have 3704884 on it , that's the order number. The 0364 brace is a first design superceded by a second design that used the same part number when ordering the brace.
      Sorry Roy, I disagree with all of the above..
      • Roy B.
        • February 1, 1975
        • 7044
        #63
        ,That's why this forum is called a "discussion Board " I may be wrong as you say and that's OK with me, and you may be right if you see the part number on the brace you say is correct. Your a great poster and I read many of your postings. Thanks
